JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
8411 runs to limit and hangs
Reply
Old 01-11-2003, 01:11 AM
Cowdog
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 8411 runs to limit and hangs
Danny,
I've got an 8411 (Reversed) doing something very weird.
Plugged it into the reciever today for the first time in a while and the servo went hard over to the limit. Being hooked up to the stabilator at the time this scared the hell outta me and I turned off the power.
After disconnecting the linkage, and turning on the system here's what I found out.
The servo rotates clockwise until it hits its limit and continues to hang until power is turned off. It HAS to have a signal to do this, ie you can leave the transmitter off and turn on the receiver and the servo is silent. As soon as you turn on the transmitter, the servo rotates immediately. When Transmitter power is turned off w/Receiver still on, the servo still hangs...
FYI here's my setup
Yellow F-18 Turbine
Reversed 8411 on Stabilator running to thru 12" extension then JR amplified Y harness and then to 940S Receiver.
Note that the other 8411 on the other stab (Runs thru same Y-harness) works fine.
This is kinda bothersome as I've had only 4 flights with this servo after replacing some 2721's..
Any ideas?
Thanks in advance..
Hank
Cowdog is offline
Old 01-13-2003, 03:23 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have you tried to swap sides of the Y, meaning switch servos on each plug in on the Y? It may be a problem with the Y harness. The other possibility is a bad amp in the servo.
dsnyder is offline
Old 01-13-2003, 05:16 PM
Cowdog
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep,
I tried swapping the harness with no luck.
Also plugged the servo directly in the receiver without going thru the y harness and still had the same problem. Duplicated the failure on other channels besides the elevator too (ie plugged the servo into rudder, aileron connector on rcvr)
Hank
Cowdog is offline
Old 01-13-2003, 05:32 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It must be a problem with the servo. Best bet would be to send it in and get it checked out.
dsnyder is offline
Old 01-13-2003, 07:40 PM
Cowdog
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ugh,
That's what I was figuring. Only bad thing is that I'll probably have to clip the wire to the servo. The wire is hard mounted behind the fuel tank... :disappoin
I'll send it ya'lls way (along with a couple 2721's that I had problems with too..)
Regards
Hank
Cowdog is offline
Old 01-13-2003, 07:44 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Please do, and if you have any further questions please let us know.
dsnyder is offline
