9303 PG MIX for Webra 160 w/MC carb help
My Feedback: (84)
WI
Hi Danny,
I an setting up a Webra 160 with the MC carburetor. The Central Hobbies web site has a how to setup for the 10X and I am trying to set my 9303 up the same way. Using a PGMIX 1 slaved to the throttle channel (master) I need to set up a curve in the slave. My question is how do I get the slave curve to move from one of the side slide levers.
Will I have to use the other PGMIX 2 as the slave to the other PGMIX 1?
Example at: http://www.centralhobbies.com/Engine...a/webrtxt.html
Thanks for you help Tom
