JR S400 Buddy Box
KY
JR S400 Buddy Box
Our club bought a JR S400 to use as a buddy/trainer box. It came without a battery but it appears it has to have a battery for it to work as a buddy box. It there a way to work around this. Our Futaba buddy box does not need a battery in it to work. Can you simply jumper the battery connector in the S400 or does it have to have a battery in it? We have a weather proof box we keep trainer cords and buddy boxes in and don't have a way to charge them at the field except for quick field charging which is supposed to be hard on batteries.
Thanks for any info.
David Palmer
President - Somerset Model Airplane Club www.smac-ky.com
David Palmer
RE: JR S400 Buddy Box
It must have a battery installed and charged.
JRPB9081 EXTRA TX NICD 800MA(WHITE CON)
JRPB955 TX NICD 700MA(WHITE CONN):4-8
JRPB5011 TX 9.6V PACK 2500MAH NIMH SANYO
Groovy, thanks for the info. I put a channel 49 crystal from one of my Hi Tech radio's in it and didn't get the response I'd hoped for. But, this radio might require a different crystal or isn't compatible with the Hi Tech receiver in the plane I tested it on. The control services responded with gimble input, but not in a consistant fashion.
Thanks again.
Sig
Thanks again.
Sig
Well, that would make sense. Just to double check, I called my local Hobby Bench and posed the same question. The answer was no, I couldn't use it as a transmitter. I told the guy I'd installed a crystal and got some response. He replied saying the buddy box wasn't tuned in or something to that effect.
I guess I'll buy a JR crystal and give it a try. It can't hurt anything.
Sig
Sig
Hold on a sec !!
Is not illegal (according to the FCC)to do what you have just done ??
Sticky http://www.rcgroups.com/forums/showp...77&postcount=1 refers...........
and also referenced here... http://www.rcuniverse.com/forum/m_6026449/tm.htm
ORIGINAL: Mac_Man_UK
Hold on a sec !!
Hold on a sec !!
