9303 Delta Speed Breaks
Denny! I have a BTE Delta wing. I want to program my 9303 to make the two rudders into speed breaks,each is on it`s own servo. The stearing has it`s own servo. Thanks, Butch
RE: 9303 Delta Speed Breaks
First I'll assume that you have set up the rudders on the dual rudder function in wing type. Next with an unused channel, say perhaps gear or any other, inhibit it in device select. Then go to a program mix, mixing that unused channel to RUDV, assign the mix to a switch, select offset and set an offset to the maximum one direction or the other, then in the pos 1 value, set the percentage as desired.
