JR PCM 9xII Use ailerons as flaps?
Hi
I have the JR PCM 9x II radio and building an airplanse using 1 servo in each wing for ailerons. I whant to use those for flaps to. Mayby use the AUX 3 lever for flaps.
It that possible?
Under wing type in system meny, i assiged the right aileronservo as "mate" for the aileron. Wing type is "normal".
Please help.
best regards Anders
It that possible?
Please help.
best regards Anders
RE: JR PCM 9xII Use ailerons as flaps?
Assuming that system sets up like the US 9303, I'd recommend switching the mate function for the aileron back off, then activate flaperon for the wing type. Then you can choose the aux 3 lever in device select on the FLAP channel.
