JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
783 and a heli
Reply
Old 01-23-2003, 01:37 AM
coony2787
My Feedback: (33)
coony2787's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 783 and a heli
Danny,
i just started flying heli's and i was setting up my 783 and the throttle trim will not work in the heli mode. what do i need to do to correct this problem. it works fine in airplane mode. i really aperciate the help you have given me in the past on this radio. thanks alot
Chad
coony2787 is offline
Old 01-23-2003, 02:26 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chad,
Check your travel adjustment values on the throttle channel. If they are 0 or close to 0, this is the reason that the trim is not working. You would need to reset the travel adjustment values back up, as close to 100 as you can, and reset your linkages so you do not overdrive the servo.
dsnyder is offline
Old 01-23-2003, 06:01 PM
coony2787
My Feedback: (33)
coony2787's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i checked my travel and went threw the program of the radio step by step i'am just missing it i can't get the throttle trim to work. any more suggestions????
Chad
Old 01-24-2003, 02:33 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One other thought, the throttle trim is only active in normal flight mode. If the flight mode switch is in position 1 or 2 the throttle trim will not work. Try flipping the flight mode switch to normal and that should do it.
dsnyder is offline
Old 01-24-2003, 02:40 PM
coony2787
My Feedback: (33)
coony2787's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok wich switch is the flight mode switch
Chad
Old 01-24-2003, 02:55 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If it is an airplane TX, it is the flap mix switch, next to the elevator dual rate switch. A heli TX may have the flight mode switch on the top left hand side. It will be a 3 position switch.
dsnyder is offline
