10x question
My Feedback: (99)
TX
10x question
Hi Danny is this mix possible and can you set center & end points with this mix.
Here's how I do it on my 10X, 2 servos per aileron.
Select QUAD FLAPS . (Code 22)
Channel 2 – Right Aileron Outboard
Channel 5 – Left Aileron Outboard
Channel 6 – Left Aileron Inboard
Channel 7 – Right Aileron Inboard
To make it all work you have to:
Mix 2 (Aileron)> 7 (Aux2) – without this mix quad flaps won’t work.
Hit Page twice and the select Trim ON and the Differential (Code 22) will work on all servos.
It’s an awesome setup because you have matchboxes built into the 10x so why not use the capability.
My Feedback: (16)
RE: 10x question
Looking to hear your answer on this also. Is this the better setup to run 4 aileron servos on an aerobatic model without using matchboxes. If not, do you have a better suggestion.
Smokey
Smokey
RE: 10x question
Yes, that is possible to do, I'd suggest setting the MASTER type in the mix to INCL also. Both set ups work well, the matchbox has a little finer adjustements than the sub trim/travel adjust settings will have.
