JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
10SX spoiler set-up
Reply
Old 01-27-2003, 02:49 PM
mark foster
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 10SX spoiler set-up
I'd like to set up the spoilers on the throttle stick, using both flap channels for each spoiler in a large glider. Could someone give a quick run thru on the method using the 10SX2.
mark foster is offline
Old 01-27-2003, 03:00 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For using flaperons you would set up a mix, throttle to flap, channels 1 and 6, and set the percentage as required. You can also assign this to a switch if you would like. If you have seperate flaps and ailerons, it depends on how you have it set up. If you are using quad flap you can just mix it the same as above, only use channels 1 and 7. If you have it set up in your own mixes, you would likely need to do a mix throttle to each channel.
dsnyder is offline
