JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Base loaded antenna
Reply
Old 01-27-2003, 04:56 PM
Texas 3D
My Feedback: (16)
Texas 3D's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Base loaded antenna
Hi Danny,
was thinking of buying the base loaded antenna from JR for my 8103 ! Question: Is there any reason I have to be worried about doing this ? Is it safe to use on SPCM and PPM ? Is there any advantage / disadvantage having a base loaded antenna ?
Thanks for your time and help
Texas 3D is offline
Old 01-27-2003, 05:03 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is no reason to be worried about it. It is absolutely safe for all modulations. The only disadvantage is that the module will get warmer than it will with a standard antenna fully extended. The module getting warmer will lead to the components losing their tuning over time, granted it will take quite some time before this becomes an issue. It is best to have the system checked out once a year if you fly often, regardless of the antenna you are using. If you do not fly that often, you would be fine for a couple years. As a side note, to use the base loaded antenna, you will need a base load antenna adapter for the 8103, that is part number JRPA156.
dsnyder is offline
Old 01-29-2003, 06:03 AM
Peter Khor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Danny,
The RF pack getting warmer isn't a good sign :-( fwiw it usually means that there's an antenna mis-match, which means that there is a noticable drop in effective RF output (the rest "reflects" back to the RF moudle, and heat). Could you confirm that it actually does heat up the RF module?!?
fwiw I am using the Smiley Duck antenna on my 8103 with no heating (or from what I can tell).
Peter
Peter Khor is offline
Old 01-29-2003, 01:40 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Actually they will get warm regardless of antenna used. If it gets hot then the system likely needs servicing, however if it is just warm, it is normal.
dsnyder is offline
