JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
x-378 again
Reply
Old 01-27-2003, 10:38 PM
beavertail
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default x-378 again
I am trying to activate the auto dual rate funtion, and when try to turn it on, the words rudd are on the screen instead of the flight mode position like the manual says. Sorry to bother you again, but I just cant figure it out.
Joey
beavertail is offline
Old 01-28-2003, 01:49 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default x-378 again
Yes, that is a misprint in the manual. That is correct for heli mode, but for aircraft mode it is not correct. It is actually automatic rudder dual rate, and what it does is as you move the throttle stick, you can set it to go between high and low rate rudder. Some instructions for this are below. I'm sorry for the confusion.
Automatic Rudder Dual-Rate
If the Automatic Rudder Dual-Rate function AUTO is active (on), when moving the throttle stick, the rudder dual rate will change from position 1 to position 2.
To Access this function, move to the D/R (Dual-Rate) screen, and press the Channel button until the word Auto appears at the top center of the screen. Press the (+) or (-) keys to turn the function on or off. To confirm that the Auto D/R is functioning, simply move the throttle stick while at the rudder D/R channel screen. If the Auto D/R is functioning, the screen will indicate D/RAT, and the D/R switch position at the far right of the screen will change from 0 to 1 as the throttle stick is moved from low to high.
dsnyder is offline
Old 01-28-2003, 04:36 PM
beavertail
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Thanks for clearing that up.
Ill pass this on to other new 378 users.
