Help,Dual aileron servo setup x378?
Hi Danny
A simple question on my Jr X-378, i do not program much..... but i need help now.
I want to use two servos for aileron setup on my new scale plane.
I will be using the Jr RS70 reciever. Could you please go through the steps with me?
What should i press and where should i plug in the servos? Do i need to program the radio or can i just plug in the servos into certain channels?
I will appreciate your help.
RE: Help,Dual aileron servo setup x378?
Turn the flaperon on in the wing type menu. Use channels 2 and 6 for the ailerons. In many cases it is also best to go to the LEVER function and press clear until it is INH to cancel the flap lever.
Thanks Danny, strange i just reversed the the plugs in channel 2 and 6 for the ailerons and it worked without changing anything, maybe i changed a setting on the model nr. previously..?,
Anyway thanks i'll disable the flap lever like mentioned, it is a scale p-51 without flaps...
Pete
Pete
