X3810 ADT reset trimmers missing
Hi
I have a JR X3810 ADT and in the instructions it says I shall be
able to test fly and trimm using digital trimms on my radio..
then go into a meny and reset so the trimvalue is still same but
the markings is returned to zero..
just to be able to make further adjustments if it just went ok
next to the limit, u got the trim levers back to zero
but the value is still the same..
one problem.. that menu is missing from my radio?
the version I have is the one with all 3 modes, Heli, plane, sail...
EU version.
Tnx for answers
EU version.
Tnx for answers
RE: X3810 ADT reset trimmers missing
I'm not sure on that system since it is an overseas system, however if you are speaking of the trim offset function, that is only present in mechanical trim systems, digital trim systems do not have that function as there is no need for it, the system automatically stores the trims for each model.
