JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
8103 Mixing ON/OFF switch select - limited?
Reply
Old 01-30-2003, 08:12 AM
Peter Khor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 8103 Mixing ON/OFF switch select - limited?
Danny,
With ref. to page 47-48 of the 8103 manual fig 4.13B shows the all the possible switched that can be used to ON/OFF a mix (no limitations mentioned). However, on my radio I can only access the following:
Mix 1 & 2 ELE>F, LAND, MIX, ON
Mix 3 - 6 ELE>F, LAND, GEAR, ON
I would like to put Mix1, Mix2 and Mix4 onto ONE switch, and the only common one is ELE>F or LAND switch - I am already using the LAND mode, and would prefer to assign either GEAR or MIX switch to ON/OFF all 3 mixes.
Do I have a firmware problem, or is this how the radio is actually setup? (in that case HZ/JR should create an update instruction sheet). fyi Radio is new, less than 2months old (8103 Promo package).
TIA
Peter Khor is offline
Old 01-30-2003, 09:25 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm sorry to say that different mixes do have different switch selections, and it looks like your radio is set up correctly. I will check into an update to the manual, I will pass that on and see what can be done.
dsnyder is offline
Old 01-30-2003, 09:49 PM
Peter Khor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As always, thanks Danny for the quick reply!
Old 01-30-2003, 10:32 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No problem!
dsnyder is offline
