JR 783 - dual elevator servos
I am flying a Showtime with the ailerons on different channels, the elevator halves are on seperate servos with a servo reverser going into the receiver. The servo reverser has a very touchy adjustment, making it difficult to really finely trim the plane. I would like to know how to put the individual elevator halves (servos) on different channels so that the individual halves can be finely trimmed.
I have a JR 783 receiver.
Ken
AMA661687
Ken
AMA661687
RE: JR 783 - dual elevator servos
In program mix E or F set up an elevator to the aux channel you wish to use, then set the rates to +100%. Then in another mix, set up a mix mixing the aux channel you are using to itself, and set the rates to -100% (the rate will need to match the travel adjust on the channel, so if you change the travel adjust on the aux channel to something other than 100% adjust this -100% to match, but remain a negative value.)
