JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Jr xp652 transmitter
Old 01-12-2007, 10:48 PM
Hircflyer
Hircflyer's Avatar
Default Jr xp652 transmitter
Just aquired a JR XP652 Transmitter and I can't find in the manual ...................how to program dual aileron servos. I want to this without using a Y harness. Most other JR's you use the flaperon function and channel 6.
Any help will be be apprecated.
Old 01-13-2007, 12:21 AM
Ken6PPC
Default RE: Jr xp652 transmitter
I have a XP652 myself. It's a pretty nice 6 channel tx! I don't regret buying mine.
Here is how I set it up with two servos for my ailerons:
First, change wing style to "Flaperon" in system mode. Next, connect the left aileron to Channel #6 (Aux1) and the right aileron to Channel #2 (Aile). You might have to reverse the throws, so be certain that the ailerons move in the correct direction. (Right stick to the right, right aileron goes UP) You can use the flap switch for flaperons, and you can adjust travel and dual rates as well.
Old 01-13-2007, 02:35 AM
Hircflyer
Hircflyer's Avatar
Thanks.........for the info I'll give it a try.
Old 01-15-2007, 10:16 AM
dsnyder
dsnyder's Avatar
It is best to zero the flap channel travel adjust to zero in at least one switch position and center the servos with the switch in that position. If you don't wish to have flaps with the switch, zero the travel in both switch positions.
Old 01-15-2007, 09:48 PM
Hircflyer
Hircflyer's Avatar
Thanks Danny
Old 02-14-2007, 07:34 AM
triniheli
Hey guys I've got the same radio with the R600 rx. Can this combo work on a heli? I've heard that it's only for airplanes.
Old 02-14-2007, 10:22 AM
dsnyder
dsnyder's Avatar
Yes, it will work fine, though I generally recommend PCM for helis.
Old 02-15-2007, 09:24 PM
triniheli
can I use the R600 with a GY401 with remote gain? I've been told that the R600 doesn't have enough inputs.
Old 02-16-2007, 09:42 AM
dsnyder
dsnyder's Avatar
Yes, you would use the gear channel for the gain.
