JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
throttle problems
Reply
Old 02-03-2003, 07:07 PM
soulman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default throttle problems
I fly an Extra 300 s .40 size with a Super Tigre 60 and a JR MAX 4 FM. Yesterday I was out and experienced what I can best describe as throttle hunting. I'll explain. After landing, I turned the aircraft around and powered up to return to refuel. The engine gained maybe 200 rpm and no more response on throttle for about 10 seconds. I turned myself so that the aerial was not pointing directly at the plane and throttle control came right back. Next. Thinking (possibly stupidly)this was a fluke, I fueled and went up again. All went well till I was about to touch down. I suddenly got Throttle hunting. 400 rpm about. Abort landing and go around. Landed without incident. Packed up and went home frustrated. Any opinions?
soulman is offline
Old 02-03-2003, 07:43 PM
vinnie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
1. Check Batteries!
2. Swap out the throttle servo.
3. CHECK BATTERIES!
vinnie is offline
Old 02-03-2003, 08:15 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The throttle servo may have a bad pot. It would be a good idea to either send in the servo and have it checked out, or replace with another servo and see if that cures the problem. Always perform a thorough range test before flying to be sure nothing is wrong. If anything odd shows up during the range test, do not fly the plane until a solution is found.
dsnyder is offline
Old 02-04-2003, 04:12 PM
soulman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the reply. I range check my plane before flying every thim I go out. In this instance I went a full 100 feet before any chatter started. I also check my battery levels w/ a digital voltmeter. tx= 10.52 v, rx= 5.30 v. I will definitely change my throttle servo and will update as I have new info. Thanks again!
James
soulman is offline
