XP9303 Channel selection
My Feedback: (16)
FL
I recently purchased a used JR 9303 TX, but don't own any JR recievers. Nowhere in the TX manual does it mention which channel in the RX to plug in the various servos for each function (ie-ail, rudd, elev, flap etc). What is JR's matchup?
My Feedback: (14)
VA
RE: XP9303 Channel selection
I hope you don't plan on using any other Rx's other than JR's or maybe in certain circumstances Airtronics Rx's and a few others that are compatible. JR uses positive shift and Futaba, Hitec and some others are negative shift. Otherwise there's no reason to know what channel sequence you need for the JR 9303. Once you have the JR Rx's you'll have that info on the Rx's themselves.
Later...
Scott!
Later...
Scott!
My Feedback: (16)
FL
ORIGINAL: bkflyer
If you go to Horizon Hobby's website and look at an enlarged photo of the JR receivers you will see that the plugs are identified on the recievers.
I don't have any JR recievers, however all my recievers (Airtronics, Hitec, Berg) are positive shift and are compatible.
