Z class JR radio
My Feedback: (14)
VA
RE: Z class JR radio
Unfortunately no. PCM "Z" is not forward compatible with the newer PCM "S" Rx's. You will need to find PCM "Z" Rx's for your radio. There are many in the used market. You can however use the newer PPM Rx's with it as long as you stay with a compatible positive shift Rx'.
Later...
Scott!
Later...
Scott!
