8417H Torque
AB, CANADA
8417H Torque
Hi Danny
I swapped out the gears in my 8311s w/ the 8417H gearset. Could you please tell me the torque and speed? I want to use them for the ailerons on a 27% extra if they will work. I am thinking 8611as. but I have these doing nothing. Thanks
Daniel
Daniel
RE: 8417H Torque
The specs would be basically the same as the 8317.
http://www.horizonhobby.com/Products...rodID=JRPS8317
If you are using the metal gear set they should be ok, but generally this servo is recommended for heli applications.
