Dual receivers
Dual receivers
Can a r950s and ner-649s be used together in the same plane. Or do they need to be the same. What do you suggest using for dual receiver setup. Also, pro and con for dual receiver setup.
THANKS
THANKS
Dual receivers
I would not recommend mixing the receivers in a single plane, if you are to use 2 receivers in a plane, use 2 of the same type. We do not recommend using 2 receivers due to loss in range as the receivers interact with each other. The loss in range in most cases is not enough to cause problems. But it is always best to set the system up for the best possible range in order to minimize the chances for hits.
