Matchbox on ailerons....
WA
Danny - putting two 8411's in each wing where each wing is driven out of a separate channel of my 8103 - as I understand the matchbox I will need a matchbox for each wing, ie, for each pair of servos. Is this correct?? Driving these with 6 volts through the receiver - any problems there?? Other serovs in the plane (two elev, one rudder) will also be 8411's on 6 volts through the receiver plus a 537 for throttle also through the receiver. Any suggestions??
Bruce
Bruce
To use the ailerons as flaps or spoilers, you would need to use 2 matchboxes. If you wanted them to work only as ailerons you could use just one matchbox with one channel, but you would need to use a battery pack on the matchbox. There should be no problems with the set up you mention. For a little added security you can run dual battery packs and switches, and use a spare channel in the receiver for the second pack.
