*Dual Elevator Setup On 7202*
My Feedback: (10)
When setting up the 7202 radio for dual elevator servos I am using mix 6 and a little unclear as to how it should be set. This is what I have. If it's not correct, what should I have?
[PROG.MIX6]
ELEV AUX2 ON
RATE: +100%
0%
SW:ON
OFFSET: +100
[PROG.MIX6]
ELEV AUX2 ON
RATE: +100%
0%
SW:ON
OFFSET: +100
RE: *Dual Elevator Setup On 7202*
Clear the offset back to 0, and set both of the rates to 100% (move the elevator stick to go between the values). Also go to the input select function and inhibit aux 2.
