JR8103 Versions?
My Feedback: (124)
JR8103 Versions?
Danny,
I have a question about the different 8103 Transmitters. I found one I might buy that I thought was the newest version because it has digital trims but the transmitter battery pack plug is black. I thought the ones with digital trims all had a white battery pack connector? Also, I noticed in the instructions that the timer beeps at 30 seconds left, does it also beep when it gets to zero like the 9303?
Tony
Tony
RE: JR8103 Versions?
The connector changed after the change to the digital trim systems, if memory serves in the last couple of years before it was discontinued. Yes, the system beeps several times before reaching the end of time starting at around 10 sec, then a longer beep at the end of the time.
My Feedback: (124)
Danny,
Thanks for the help. I just want to make sure I understand you and I want to make sure I am getting the newest version of the 8103. There is no difference in the transmitters other than one connector is black and one is white?
Thanks again,
Tony
Thanks again,
Tony
