JR 9303 and split elevators
TX
Danny, I have a plane with split elevators, (separate servos), and do not know how to make them work together.
I have been told to mix them but do not know how to set up the mix on a JR 9303.
My Feedback: (66)
RE: JR 9303 and split elevators
I know you did not ask no one else but here how you do it.
Elevators
Plug one side of the elevator into the ELEV channel and the other side into the AUX. 3 channel. Go into the System menu and choose Wing TYPE. Jog over to the Mate line under ELEV and push the roller button. A box will appear with 4 choices: GEAR, AUX2, FLAP & AUX3, choose AUX3. You have just mated the AUX3 channel with the Elevator channel; the radio will now refer to these channels as REL (right elev.) and LEL
Elevators
TX
Wlouigene, a correct answer from anybody is fine. Thanks.
I am using a JR 7 channel rx and it only has AUX 1 and AUX 2. No AUX 3.
I guess I can just use the AUX 2?
I will try what you say.
You can use any of the aux channels, inhibit the aux channel in device select, then in the wing type menu select that channel under dual elevator.
