JR 7202 wont' select models
OR
Hi Danny, Wondering if I should send the radio in, thought I would check with you first. The model select stops at 4 and the radio locks up. I can turn off and turn on and go the other way and it stops at model 2 and locks up. Basically the radio won't let me select models 2,3 and 4. But I can select any of the other model numbers. Any ideas??????
RE: JR 7202 wont' select models
It sounds like there is a problem with the system and it will need to come in for service to have this corrected.
http://www.horizonhobby.com/Content/...rchecklist.pdf
