JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
12X module system
Old 04-12-2007, 03:46 PM
staggerwing
staggerwing's Avatar
Default 12X module system
Danny will there be a version of the 12 X that will use the existing modules for 72 and 50 mhz?
Old 04-13-2007, 03:39 AM
Mac_Man_UK
Mac_Man_UK's Avatar
Default RE: 12X module system
The last info I received on the 12X ( Tuesday 10th April) from JR Japan was that the 12X is a synthesised system along the lines of the 7202 (2720). I believe that if they went the modular route, then a new module would have been needed as the current systems are designed for a maximum of 10 channels.
Old 04-13-2007, 09:27 AM
staggerwing
Thanks Mac Man. Looks like the end of support for us 50 mhz flyers. There will be an upside to this. I'll be able to pick up 10x's and 50 mhz receivers dirt cheap as others move to 2.4 ghz or to the synthesized 12x. Since I'm the only Ham in the county, I have no interference problems!
Rich
Old 04-17-2007, 12:26 PM
dsnyder
dsnyder's Avatar
No, at this time there are no plans for a 72 Mhz system in the US, only 2.4 Ghz.
