Loss of control in flight using AR7000 & DX 7 UPDATE 5/5/07
#51
RE: Loss of control in flight using AR7000 & DX 7 UPDATE 4/24/07
RE SPM1600. This is not a NEW fix. If you take a look this first came out for Spektrum receivers in RC cars. So I would have thought Spektrum would have improved their DSM2 receivers so this would not be needed. I normally run 6 volt batteries with either 1650 or 2700 mah. Battery voltages were checked and my total loss of control was clearly NOT due to my batteries being low. The the largest A/C was 60 sized and was running 6 servos.
#52
My Feedback: (121)
CA
Craig,
Did you send your stuff in for HH to look at. I was wondering if they even speculated on the cause. I remember you posting a while back and thinking that you had the appropriate battery for your system. Could you have gotten a bum rx?
#53
My Feedback: (42)
NJ
RE: Loss of control in flight using AR7000 & DX 7 UPDATE 5/5/07
*****Update April 24,2997****
I flew today with the voltage protector install. Four flights no problems. This plane has been rock solid from the first flight so adding the cap did not screw up anything. Still waiting to hear from Horizon about the reciever I sent back for eval. Will update when I hear from them.
Six
Six
#54
CA
NJRCFLYER2
I agree with you 100%! That capacitor is a poor bandaid to this problem. I am running 6.0 volts setups from now on and no more digital servos. Spektrum and HH are getting a black eye on this one for sure!
Six
Six
#55
The solution to this problem is to use an rx pack that will deliver the higher amperage needed without dropping the voltage level. I had some packs made up by a UK based company called 'component shop' (the guy, Ian, really knows his cells) and they are capable of delivering 15amps +, without the voltage taking a big trip south. Using packs made from AA cells will always be a problem as far as voltage drop is concerned, due to their inherent, high internal resistance. Increasing the capacity will not allow the voltage to stay higher. Under low amp loads, they will work, under high amp loads they will drop their voltage VERY quickly.
The packs I use are 6v 1400mah and are fast chargeable at a 1c rate, meaning, I can recharge at the field every 2-3 flights.
ALSO, invest in an onboard voltage monitor, placed where you can easily see it at switch on before every flight. The packs I am using are only about a half ounce heavier than the AA packs they replaced. In all honesty, most .60 size aircraft could handle the weight of even sub 'c' size packs without any problem at all. The majority of these cells will provide the amps without the voltage drop.
Just my tuppence worth, but it works faultlessly for me.
BTW, if you're using cheap rx packs, think twice............... there's no such thing as a free lunch!!!!
Heres a link to the cells I use. I had them reconfigured as 5 cell packs with standard futaba/hitec plugs and high quality silicone wire.
http://www.component-shop.co.uk/html/6vp1400afp-w.html
#56
My Feedback: (42)
NJ
#57
ORIGINAL: NJRCFLYER2
Right! They ought to just pull the 4 cell NiCad out and replace with something substantial or just eliminate it entirely, plus amend the manual to explain the proper care & feeding of the receiver from a power standpoint. BTW, I didn't mention it before, but the other poor aspect to the capacitor patch is that a 4700uF cap is going to look like a dead short to the switch contacts at the moment they are closed when turning it on each time. That's bad for the contacts and will shorten their life. The answer - just say NO to the "voltage protector" and get a good set of batteries as you advised.
Actually, higher spec battery packs are my solution to every manufacturers sets, not just Spektrum DX sets. Even standard servos can pull stock AA packs down to low voltage levels. You wont find a standard pack on any of my planes....... been there, done that and swept up the mess!!!
If your pack goes on the fritz, you are going to loose control, NO doubt about it. So, make sure you have the very best pack you can justifiably afford and if you cant afford a pack that can hold it's voltage under the current draw of all of your servos added together............well, I'll leave that to your own thoughts. Redundancy is well worth a second look too!
I'll bet, a few of the problems related here, could have been nullified if the planes had been fitted with better packs. Now, I wonder how the standard DX7 rx pack would fair if it was put under a full 4 servo stall/ amperage drain?? Bet the voltage would be lower than the cut-off for the Rx. No, I haven't tested it, I just eliminate potential problems instead of fixing the ensuing disasters.
#58
My Feedback: (42)
NJ
Re. conventional receivers "browning out", sure it can happen! It just seems like the margins are reduced with this particular Spektrum receiver and you have to be careful to choose batteries well.
#60
My Feedback: (42)
NJ
ORIGINAL: RobT
Would these issues be resolved by using two packs instead of one? (even if they were AA packs?)
As far as the AA packs, it's going to really depend on the servo load you're putting on it as to how well they will perform. These days I like either a dual LiPo regulated setup or even something like the A123 Li Ion would be appealing.
#61
My Feedback: (121)
CA
ORIGINAL: At_Your_Six
NJRCFLYER2
Six
NJRCFLYER2
Six
I really seems like JR is behind the curve when it comes to rx packs.
#62
NM
"Personally, I don't like the NiMH packs much anymore due to the higher impedance that most of them have and they also don't seem to age well. The dual pack idea is just for redundancy safety, not really to fix the voltage dropout in normal operation."
Low input impedance for the Rx to look at is important, and two NiCd packs in parallel provide that. Not only do they provide redundancy, but the added capacity of two packs in parallel suppresses voltage fluctuations, and heals drop-outs. All 3 of my Spektrum installations include parallel packs and switch harnesses. DX-7 / AR7000 works as advertised !
> Jim
Hi Craig, sorry to hear about your problems. See you at the field.
> Jim
#63
My Feedback: (174)
CA
I just found this forum. I had the same problem about two weeks ago and couldn't figure out what happened. I've been flying my Funtana X 100 with the DX7 and 7000 Rcvr with about 30 flights on it, airplane was flying along fine straight and level and just started to decend at about a 45 deg angle no control, took out the nose section and damaged the wings. I was useing 4.8 v pack fully charged. the crash was about 5 min into first flight of the day. I don't think it had anything to do with Tx as I'm using it with my electrics with 6100 Rcvr's and never have a problem. After the crash and I tried the radio and it worked fine but I'm kind of scared to try it again in a new airplane, I have 3 of the 7000's with one mounted in a 1/3 scale Laser, from everything I have read I think I'll got to twin 6 volt packs. Will call HH tomorrow.
#64
My Feedback: (17)
NY
All of my setups are either twin 6 cell packs, or twin Lipo packs (with regs) I have not gone to spectrum yet but will soon as the modules should be shipping in a day or two.
From what I have seen all of the reported crashes are with single pack setups.
#65
My Feedback: (18)
CA
Anyone actually heard something from HH? All the suggestions here are speculation,possibly correct speculation, but it would be nice to hear from the people that make the things.
Seems to me there is a real problem with the DX7.
#66
My Feedback: (121)
CA
ORIGINAL: jetessmann
If you were flying straight and level with a fully charged pack then you probably had very little load on the pack. Why do you think that a different pack configuration will solve this issue. You probably weren't even pulling 1 amp out of that pack at the time.
Some of these crashes like this don't sound like pack issues. Others do but this doesn't. One crash a while back was very similar in nature and with a 6 volt pack. Doesn't anyone think there could be a receiver production issue?
#67
My Feedback: (121)
CA
ORIGINAL: RobT
#68
My Feedback: (17)
NY
I have to admit you are right. Even though I have lost airplanes because a battery or switch failed and went over to duel setups . . . which if done right do not have to add significant weight or cost . . . does not mean we should have to with any new receiver. If these receivers were designed correctly they would be plug and play into any correctly setup system.
What are you going to do to fix the issue HH?
Is their going to be an issue with the 9000 receiver?
#69
My Feedback: (121)
CA
RobT,
If I were flying more expensive birds I would follow your suggestion to the letter. But, for a 60 sized bird it's not worth it. I sure hope Spektrum comes back with some info on this soon.
OK, real question. On a smaller plane how can I get that redundancy with 2000 mah capacity in about 6 oz of weight?
#70
ORIGINAL: seanpatsdad
I lost a Ultra Stick 40 last week.2nd flight of the day ,probably about 7-8 flights on plane with new radio.I was on base turning onto final and just lost everything.No response to any input.When I got to the wreck I had no movement,I shut off plane and turned back on and everything worked fine.I am going to up my battery to a 6.0 volt package.I was not running any crow function just full lenght aileron.Still like the radio.
John
John
#71
I've been following this thread with interest. I have 2 large electric helicopters and a bunch of large gassers on Spektrum. However, I just put my 35% QQ yak and Extreme Flight 88" Yak back on PCM until we know definitvely the root cause. I use single and dual Li-ion battery set-ups with Smart Fly regulators. I'll fly my beaters on Spektrum for now. Steve
#72
My Feedback: (121)
CA
I'm thinking about moving my Spektrum stuff to my foamy until I see at least an explanation that makes sense. For some cases, I don't buy the voltage theory. It's happens but not to guys floating in on final with a charged pack on a glow plane.
#73
WI
Yes, I did have a complete loss of control on one of my three DX7 receivers. It happened on the ground in my front yard after several hours of "burn in time". Had this occurred in the air, it would have cost my model.
My background is 45 years of electronic repair, so was very interested in what happened.
The failure was traced to the DX7 receiver. The receiver was receiving a signal, but all four servos were dead. The failure was traced to a "Plated through hole" on the DX7 receiver, that caused loss of power from the battery center positive lead and all center positive leads of the servos. The plated through hole was not plated through. A quick solder job fixed it. A call to Spektrum resulted in "Never heard of that one before".
The other two DX7 receivers were given a micro-ohm test, no problems were noted. All three receivers have had a number of flights with no problems.
Also ran tests on one of the DX7 receivers on a variable DC supply that allowed dropping the 4.8 volts DC to lower levels. The DC was monitored by my Tektronix 2236 Oscilloscope. Repeated tests showed that the DC had to be dropped to 3.1 Volts DC before the DX7 re-booted itself. The "Patch Kit" Spektrum sells for about $6.00 covers this issue.
#74
Very interesting, fly...
How much will you charge to diagnose mine? Sounds exactly like what did happen to mine in the air.
So, if that is the case, buying that patch kit wouldn't fix it would it?
#75
My Feedback: (121)
CA
Fly,
Would what you describe cause intermittent loss of signal or did it just die after a period of time. Could the rx be made to work again after turning it off and on?
Also, how long would the capacitor cover a low voltage condition for?
If Horizon doesn't seem interested maybe you could charge a fee for inspecting receivers. Or, teach me how and I will open a business. Anyways, I would love to know what to look for. Anyhow, you might want to email them and start a new post on the manufacturers site. Someone at Spektrum needs to get the message.
