9303 Latency Programming?
My Feedback: (198)
Wondering on the 9303, can I set it up for dual elevators, using the "Mate" function, choosing "Gear" as the second elevator, if I INH Gear in the Device Sel function?
It would be several channels "earlier" in the pulse train if I could..... any ideas??
My Feedback: (198)
RE: 9303 Latency Programming?
Excellent, Thank you!
So - is it correct that since I've disabled the Gear in Device Sel, that I can use one of the AUX channels as a "choke", and actuate it with the GEAR switch??
ORIGINAL: krayzc-RCU
bob i do it that way when i use a 6 channel receiver and then make the gear the mate for trim purposes also...
