DX7 and Charging.
DX7 and Charging.
Brand new DX7 user here. I was reading the manual about charging the rx and tx. Can I use an Acer super smart charge or a hobbico accucycle to charge setup with? I hooked it up to the wall wart for the over night initial charge. What about quick charging and such? Thanks for any and all advice.
RE: DX7 and Charging.
G'day Mate,
Use the wall charger for about 30 hours, to balance charge, see here,
http://members.aol.com/davthacker/balancecharging.htm
Follow these directions, & your batteries will last longer.
I don't use the Ace Smart charger for my TX batteries, as the Smart charger Tx charging section is only rated to 1000Ma, & your battery is 1500Ma, so I slow charge when needed.
I found the Ace would not shut down to slow charge, it was still charging, at 12Volts, lucky I was watching it. Anyway I only need to charge that huge capacity TX battery about once a month.
Thanks for your help..... On the wall wart right now.... I charged it for 16 hours with the wall wart last night, flew a couple of flights today... I think I like the 2.4 very well...
As long as the polarity of the charge plug is correct, center pin negative, you can use any charger that is compatible with 8 cell Nimh batteries. I recommend keeping the charge rate to 1 amp or under.
