retracts on h9 p51 77 inch
NY
I was wondering if you could help me with getting my retracts to work. I am using jr servos and a futaba radio. It will work with futaba but I cant get the jr servos that are ing the plane to work.Thank you,David
RE: retracts on h9 p51 77 inch
If you are speaking of a retract servo, you will need to use a 4 cell battery pack. Otherwise I'm going to need a bit more information to assist further as to what is happening and what equipment you are using.
NY
Thank you, That worked, I now have chattering from both retract servos though. I tried end point adjustments but that didnt change it. They aren't supposed to make noise are they?
IA
Danny can take it from here, I was only referring you to what he said above (since this is a manufacturer support forum, not a typical discussion for all of us to chime in For what it's worth...I have a set of the 791 retract servos, one std, one reverse, neither chatter. (sorry danny)
Retract servos are not adjustable via the transmitter, they are not proportional servos. It sounds like your linkages need to be adjusted. To get more throw go out on the servo arm, for less throw go in on the servo arm. It sounds like you either need to adjust the length of the pushrods or perhaps have too much throw, in which case you will need to move the connection points in on the servo arm.
