JR PCM 9x VII elevator mixing
Hello,
I have a 3D plane that has individual elevator servos acting on each half of the elevator, which is pretty standard.
However I would like to be able to program my JR PCM 9x VII so that while on the fly they can be switchable to act as 'tailerons / elavons', to increase the roll rate even further.
I assume the fuction would sort of be like 'crow', but with a mixed aeileron function as well?
Any ideas how I would do that?
RE: JR PCM 9x VII elevator mixing
Assuming that it is the same as the US 9303 system, and assuming you have set up dual elevator in wing type, set up a program mix, if you want it to work with the aileron stick set aileron as the master, then set AILV as the slave channel, select a switch and set the rates as desired.
