Problem solved / ignore
NJ
EDIT: Problem solved, I had the bind plug in the wrong spot.
I have an AR7000 rx that I am trying to bind to my DX7. I have already used this tx with an AR6100. When I connect power to the receiver via the throttle channel from my speed control or the switch and battery included in the radio to the battery channel, I do not get the blinking lights on the rx. The lights light up just as I am connecting power and then go out after a split second. Am I doing something wrong here or is it possible that I have a bad receiver? I have also tried just hooking up the batter directly to the receiver bypassing the switch and still no luck. Will the receiver flash only when the bind plug is in and which channel does the bind plug go into? I did not think this mattered.
Brian
Brian
