Earth magnets and interference
IN
Will using "rare earth" magnets to hold hatches and other misc. parts in place cause radio interference? Came up at the field today, and now I'm questioning a decision I have made. With the magnets being as strong as they are, I wonder if the lines of flux from the magnetic field will react with the receiver. JR 790 PCM and probably standard digital servo's.
CA
RE: Earth magnets and interference
I'd like to revive this post. Just yesterday, I flew a new electric with a previously flown single conversion Rx. In the new model, the Rx antenna passes within 1/4" of the rear hatch magnet (rare earth), and I was seeing glitches on all channels momentarily as the plane passed the TX antenna axis (or within about 5 degrees). I've not seen this before on this particular Rx/Tx combination, and the previously "good" combination was with a brushed Speed 400 motor, the newest an outrunner.
I may re-route the Rx antenna, fly and repost results.
Wow, I never thought of these little magnets that I buy at Radio Shack would have a issue.
Been useing them for years with NO problems. I usually have two of them on my large gas planes to hold the wing bolts and and hatch screws.
I have a small electric model with a outruner motor and the light JR reciever and the Magnet is about one inch above the antenna with no problems.
But it is something that I will keep in mine when glueing them in place.
Jim
Jim
CA
I'm not sure the magnet is the problem here - just a possibility. There may be other issues with the Rx or antenna routing. We'll see this weekend, and I'll re-post.
