Help MacMan!
Help MacMan!
Just trying to program my PCM 9Xll, cannot get the 2 elevator servos to operate together with the MATE function using Aux2 for the left elevator.....works OK if I use Aux3 though??
I have disabled the switches and Aux 2 is available to use in the Mate function....but it doesn't respond.........Help please!
John
John
RE: Help MacMan!
John, confirm that in Device Select Aux 2 is set to INH, Wing Type set to Normal, Dual ELEV's Mate is set to AUX2 ?
I just tried that on my 9X and 9XII and it works fine.
If in doubt, select an unused model memory and clear it, then just set the above conditions to test the system.
RE: Help MacMan!
Thanks MacMan...... I checked that all was set OK...it was.......... then I cleared a memory and tried again......It worked OK!
I have just used the DataXchange program to transfer all models from my 3810ADT to the new PCM9Xll...... seems there must be a bug there....or should i have cleared all memories before starting?
John
John
RE: Help MacMan!
Ideally you need to clear all model memories before loading from another set or DatXchange or even setting up the long way.
Glad to see that you are up and running !
RE: Help MacMan!
[&:]I've found the actual reason why the DataXchange loaded the problem....I had a dual servo elevator setup in the 3810, so the travel adjust on AUX2 was set to 0% to prevent operation with preset knob/switch.... as the PCM9X11 uses the Mate function to achieve the same result, I didn't notice that the travel adjust was still set to 0% and consequently transferred with DataXchange, even though the mix had been setup OK []
