Dual elev set up with 7channel rx
FL
Is it possible to setup dual elavotors on my 10x with a JR 7channel rx and have the R-AE/EL pre mix function work?
Mike
Mike
GA
RE: Dual elev set up with 7channel rx
yes...your snap function will not work however. I set mine up by mixing channel 3 and channel 6...I did program mix using 51..and channel 3 as master and enabled trim functions...I also went to 17 and disabled the flap switch...
