Help setting up gyro on 10X
I have a Jr voyager E and I am using a 10x with a R700 RX with is a 7 channel Rx and the gyro is a jr 460
The problem I am having is the 10x has the remote gain mixed to Aux 3 and I don't have a aux 3 I only go up to aux 2
What am I to do
David
What am I to do
David
David,
The easiest solution would be to just use the aux 2 or gear channel and use your travel adjustment to adjust the gain. Or you could do an aux 3 to aux 2 mix, with 100% values each side to make the aux 2 channel follow the aux 3 channel. I hope this helps!
