9303 Twin Engine Programing
WI
I want to use the twin engine function on the 9303. The manual page A-15 reports that from the system menu "highlight and INH next to Mate under Twin E. A sub list is to appear (Gear Aux2 Flap Aux3
The sub list does not appear. What am I doing wrong. I have a flaperon wing set others on that screen are all set as inh.
Scott Orten Grafton WI
RE: 9303 Twin Engine Programing
You will need to inhibit the channel you wish to use in device select before it will be available to use as a dual channel in the wing type menu.
