XP9303 and aileron differencial
Hi Dany!
I have a Showtime 90 4D and I can't figure out how to setup two or tree flight modes with different ATV for each up and down aileron.
I have seen new planes that comes with different UP and Down aileron travel for different flight conditions (normal and 3D, for ex.)
I must program:
Low 2" Up 1 7/8" Down (Flight Mode 0)
High 3 3/4"Up 3 5/8" Down (Flight Mode 1)
As you can see, I must use aileron differencial IN EACH Flight Mode.
Hpw can I set up 9303 to have several aileron differencial setups FOR EACH FLIGHT MODE?
For elevaton (dual chanel) I solved the problem by adjusting different travel by dual rate in each flight mode. BUT both elevons goes the same way - both UP and both DOWN.
If I use this setup to ailerons - one (right) will have the same travel (UP) as the one (left) DOWN!! because the go to opposite direction
Thanks any help.
Henrique
I must program:
Thanks any help.
Henrique
