jr 9303 idle up switch?
Hi
I think i ahve it part way figured out i need to ahve an idle up switch so that i only go into low idle on final approch i ahve the "mix" switch free how can i set this up? i ahve it working somwaht but the switch is in the wrong directtion (i want it so that when it goes "down" the idle is low and up for high idle also the way its working now (using mix #1) the idle up is more like 1/2 throtal a bit too much
please help set up...
RE: jr 9303 idle up switch?
ORIGINAL: krayzc-RCU
i use the gear switch on a mix for my idle up
That could be an option.... then i get idle up when the weels are up and i get my "ground" idle when the wheels are down but would the throtal stick ahve any effct on the wheels i dont want them movving as i moove the stick[X(]
My Feedback: (31)
NC
mix three put in gear to throttle
pick a number to get u started on the lower number around -15 or + 15 click you gear and u will see the throttle servo move just a little bit. pick the correct location u want the switch to be by what number u pick on the postive or negative.
adjust that number 15 to get the correct rpm u need....
(one a side note i ended up using the mix switch becasue then i can fly my 2 laps with teh gear down (ensurein the weels are down) and i will only hit the low idle when i about to touch down and know that i can make the runway
