Servos no work!!!!!!!
My Feedback: (82)
AZ
I am converting all my planes to Spetrum and have run into a problem. I have a 10X with the Spectrum module and an AR9000 receiver in this plane. After binding and removing the bind plug, there is no movement of the servos, even tho the lights in the receivers are all on. This is about the 7th plane I have converted with no problems on the other 6. Any ideas?????????
My Feedback: (60)
RE: Servos no work!!!!!!!
Is the secondary antenna plugged in? I'll bet you're gonna come on here and go "DOH"! If I am wrong, you have a bad receiver, and I have come across that before, I just sent it into Horizon last week same issue.
I thought I found another bad one this morning, but realized after I started pulling leads out of the receiver that I left the secondary antenna unplugged. [:@]
Try rebinding the system, also make sure your batteries are fully charged. If you are standing close to the model, take a few steps back and see if it links up.
