Six digital servo....too much loading on battery/switch harness?
I am planning to use five JR DS9411 and one DS821 servos for my showtime 50. DS821 is for throttle. RX Battery is 2150mah JR NI-MH. Switch harness is standard small JR switch harness JRPA003. Will I create too much load on the RX battery, considing I am using six digital servo running off the RX battery? Will the switch harness/battery to switch connector/switch to receiver connector be under too much current loading? If so, which switch harness should I use?
Thanks!
Thanks!
