JR662/ Slimline R700 question
ID
Getting ready to program and setup my Hangar 9 Ultra Stick using quad flaps configuration. The instruction manual covers programming with the JR652 and R600 rx but not the R700 receiver. Do I use the the same ports oulined when using the R600 or should I be looking at using the AUX2 port somehow on my R700. I realize that I will be using a "Y" harnes for the flaps just need info regarding the R700 versus R600 differences and/or any other info to ease the programming for the JR662 and R700 rx combo in this application.
Thanx in advance
Lobob
Thanx in advance
Lobob
You will use the same channel numbers as the R600. You will not be able to use the aux 2 port, as it is channel 7, and you have a 6 channel radio system. You will just need to follow the programming instructions for the 652 that are in the ultra stick manual, and you will be set to go.
