JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
.50 size heli servos
Reply
Old 09-07-2007, 02:43 PM
shall36
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default .50 size heli servos
Danny,
I have a Raptor 50 and I would like to upgrade to digital servos. What JR servo would you recommend? I don't need the Best servo out there, but something that is designed to handle the load of 3D aerobatics (nothing super extreme).
Thanks!
shall36 is offline
Old 09-07-2007, 03:15 PM
arobatx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: .50 size heli servos
I used JR8231 digital servos and had very good luck with them in my .50 sized 3D helis.
arobatx is offline
Old 09-08-2007, 07:17 PM
shall36
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks! I picked up two of these for my cyclic controls.
I have a G500T with 810G servo. I'm looking to upgrade to a digital JR servo for the gyro and would prefer something that can handle 6.0V. Does anything in JR fit that bill?
Thanks!
shall36 is offline
Old 09-10-2007, 08:37 AM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tail servos are designed to handle up to 6V, but they will not handle a 5 cell nicad or nimh battery pack. If you intended to use higher voltages, I'd recommend a voltage regulator on the tail servo / gyro.
dsnyder is offline
Old 09-10-2007, 10:59 PM
jschenck
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
very nice but you'll need to regulate it to 5V
http://www.jrradios.com/Products/Def...odID=JRPS8900G
jschenck is offline
Old 09-11-2007, 11:06 AM
shall36
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I assume they can't handle the 5-cell NiMH pack because when fully charged, they put out more than 6V?
Sounds like I need to get a voltage regulator (6V) AND a step-down (5.1V) for the gyro/tr servo. Kind of weird to put a voltage regulator on a NiMH pack (I think LiIO when I think voltage regulator), but OK.
In doing a lot of searching, the 6V regulators that I see are designed to work with LiIO packs. For example, Align has several regulators and step-downs, but the descriptions indicate that the regulators are for use with LiIO packs ONLY. SO, what do I need to buy here? I have two 6V 1500mAh NiMH packs that I want to run in parallel. I need a step-down for the tail rotor servo/gyro. Can I buy just the step-down from Align or Duralite? Do I need to couple the step-down with a 6V regulator? What regulators are out there designed to work with 5-cell NiMH Packs?
shall36 is offline
Old 09-12-2007, 08:40 AM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Correct, a 5 cell pack will in general be higher voltage than 6V, even when not fully charged. You may not need to regultate anything besides the tail servo/gyro. I've heard of some regulators out there that are simply for 2 channels (tail servo and gyro gain), I'm not sure who all has them, but I believe Align may have one and possibly some other companies as well.
dsnyder is offline
Old 09-12-2007, 08:46 AM
jschenck
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes you can buy the Align voltage stepdown separate Align part#K10333A
http://grandrc.com/inc/sdetail/60060
but this is a .9 volt drop, not a regulator. so if your NiMH pack drops to a lower voltage and then you cut .9V off from the tail you could potentially run into a low voltage reboot of your gyro. I run this between the gyro and the tail servo which would at least minimize this risk.
You may want to consider running a lipo anyway. Align has a really nifty device which gives you a 2S lipo, a voltage regulator for the flight servos and an on board glow lighter for less than $60
http://grandrc.com/inc/sdetail/88836
jschenck is offline
Old 09-12-2007, 08:54 AM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That isn't the item I was referring to from Align, they have a 2 input/output regulator, or have one coming.
http://www.horizonhobby.com/Products...dID=AGNHE50H05
Other similar devices are available as well.
dsnyder is offline
Old 09-12-2007, 09:39 AM
arobatx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here you go: http://www.gravesrc.com/ProductDetai...50H05&CartID=1
Chad
arobatx is offline
Contact Us Archive Advertising Cookie Policy
