X-378 Servo Speed
X-378 Servo Speed
Hello Danny,
I have an X-378. It works very well for the most part.
The question I have is with dual elevator servos right servo to elev channel and left servo to aux2 the left elev speed always seems to be behind the right elev.
This has happened on 4 planes with 4 different receivers and all different servos. Some of the servos are 8411 and some Hitec.
If I connect any to a y-harness then they operate at the same speed.
Do you have any ideas.
Lenny
Lenny
X-378 Servo Speed
Lenny,
To set up dual elevators, first make a mix in mix 5 or 6, elevator to the aux channel, and make the percentages +100% with both up and down elevator. Then in mix 3 or 4, set up another mix, where you will mix the aux channel to itself, and make both of the percentages -100%. Then be sure that the travel adjustment values are the same, or very close, and that there is very little sub trim on those channels. I hope this helps!
