8103 Flight Mode for Dual Rates
My Feedback: (7)
Danny,
I'm sure this question is somewhere in here but can't find the specific answer. Can a 8103 have a high dual rate for ele and ail setup on the 3 position flap switch or will I need to upgrade to a 9303 for that function? I'd like to have one switch for snap throws that's easy to access.
Mike
Mike
RE: 8103 Flight Mode for Dual Rates
That is not a function in the 8103. You can set up multiple program mixes, mixing the channel to itself (elevator to elevator etc), assign them to the same switch, and use negative rates to take away throw.
Please begin a new thread if you have a question. Set up a throttle to throttle mix, assign the mix to a switch, and set negative rates to take away throw.
