DX6 Wing Programming
Am about to pull my hair out - can anyone help me with programming a flying wing with my DX 6. It seems if I get the ailerons working right, I can not get the elevators to work right. I've tried servo reversing to no avail. Do I have to mount the servos/arms in a specific orientation to obtain the correct programming? If so how? Thanks Hal
RE: DX6 Wing Programming
To begin setting up a delta/flying wing set up, get your ailerons moving the correct direction. If the ailerons are backwards, reverse the channels as required. Then if the elevators move the wrong direction, swap channels that the servos are plugged into the receiver, and it will reverse the elevator without affecting your ailerons.
