How do I?
RE: How do I?
G'day Mate,
I'm not familiar with that radio, but if you set the wing type to Flapperon, & plug the right aileron servo into "AIL" & the left aileron servo into "AUX1" in your RX, it should work as you want. you may need to reverse one or both servos to work in the proper direction.
RE: How do I?
Danny: I finally got both ailerons working togethet in right directions. What happens if I do not set the travel adjustment on flap/aug? Bythe way...How do I set that? Thanks Capt,n
