Flaperons
Flaperons
I'm trying to set up flaperons on a JR 653 and can't get it to work.
I have set the flaperon setting on and have the servos in the Aleron and Flap channels.
The servos operate in oposite directions together but when I move the switch to drop the alerons the servos move the same direction ie one aleron up and one down.
I have read the manual and have tried everthing .
What am I doing wrong?
RE: Flaperons
If your flaperon set up is set such that the ailerons are moving the proper direction, it is not possible to have the flap switch operate them in opposite directions (one up and one down). You might try begining with a clear model memory in the TX, do a reset on the model, and reset to make sure there is no other programming affecting the set up.
