JR XP652 how to Aileron & Rudder identical
OR
Greetings:
I have been flying a Slow Stick for some time now, it's rudder is controlled by the aileron stick of my JR XP652. I would like, in addition to the aileron stick, to make the rudder stick also control the rudder; that is, so that I can begin to use the rudder stick while still being able to use the aileron stick to get out of the trouble that using the rudder stick got me into.
Can someone help me with the programming to accomplish this?
Mike
Mike
RE: JR XP652 how to Aileron & Rudder identical
If the rudder is plugged into the aileron channel, set up a program mix, with the master set to rudder and the slave to aileron, and set the rates as desired, say 100% if you want full travel.
OR
Danny
I found an aileron to rudder mix in my radio and I set it to 100%. As before, when I move my aileron stick the rudder moves accordingly (rudder servo is plugged into aileron in the JR Micro Receiver) but when I move the rudder stick, I get no action. You mentioned "with the master set to rudder and the slave to aileron" While I love the terminology, I can't find any master/slave settings in the radio nor mention of them in my XP652 manual. What am I missing here?
Mike
Mike
You don't need an aileron to rudder mix, you need a rudder to aileron. You need to go to a program mix, set the master in the mix to rudder and the slave in the mix to aileron. The first channel in a mix is the master, the second is the slave.
OR
Ahhh. Are we talking about using the "Programmable Mixing (A, B, and C)" ? I'll take a look at that section of the manual.
Mike
