8103 and throttle cut switch location
My Feedback: (16)
I was wondering what switch or knob i can use for throttle cut for a gas engine? A programming guide would be nice.
Smokey
Smokey
You can send an email request to [email protected] and we can email you a programming guide. For the throttle cut, you will need to set up a throttle to throttle mix, and assign it to the switch of your choice, you can choose the gear switch, the flap switch, or the mix switch. Then you will put the switch in the position where you want the cut active, and put in a postive percentage below half throttle to bring it back, or a negative value above half throttle. If you have any further questions on setting this up feel free to give one of our techs a call at 877-504-0233.
